<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="190" width="413"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="update_database" compatibility="5.3.000" expanded="true" height="60" name="Update Database" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|a1|a2"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Update Database" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
