[SOLVED] RM UNUK - compiling error - .lock
Hello everyone,
I have just switched to Rapdiminer Unuk and I have some problems with compilation.
At first I would like to say:
- compilation with RM Vega was OK
- the problem was repeated on 2 independent computers
- the error is not related to java code (it seems that the problem lies in ANT RapidMiner_Unuk\build_extension.xml file)
The reported compiling error is:
(RapidMiner_Unuk\build_extension.xml:129)
<antcall target="build.dependencies" />
(RapidMiner_Unuk\build_extension.xml:181)
The problem seem to be that the "FOR" cyclus tries to iterate over each file in the workspace. Any help would be really appreciated.
Best,
Radim Burget
BUILD FAILEDThe problem is in particular in:
C:\workspaceRMUnuk\RapidMiner_Unuk\build_extension.xml:129: The following error occurred while executing this line:
C:\workspaceRMUnuk\RapidMiner_Unuk\build_extension.xml:181: The following error occurred while executing this line:
C:\workspaceRMUnuk\RapidMiner_Unuk\build_extension.xml:186: The following error occurred while executing this line:
Error reading project file C:\workspaceRMUnuk\.metadata\.lock: Process cannot work with file, or other process locked part of this file.
<for param="buildfile">(RapidMiner_Unuk\build_extension.xml:186)
<path>
<union refid="build.dependentExtensions.actual" />
</path>
<sequential>
<ant antfile="@{buildfile}" target="install" inheritall="false" useNativeBasedir="true" />
</sequential>
</for>
Best,
Radim Burget
1 - 2 of
21
I think this one got someone else recently, check out.
http://rapid-i.com/rapidforum/index.php/topic,5062.msg18886.html#msg18886
Hope that helps.
