<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="540" width="835"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.006" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="xyzA" value="1"/> <parameter key="xyzB" value="1"/> <parameter key="xyzC" value="1"/> <parameter key="T" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="set_macro" compatibility="5.2.006" expanded="true" height="76" name="Set Macro" width="90" x="179" y="75"> <parameter key="macro" value="plot_list"/> <parameter key="value" value="INIT"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.006" expanded="true" height="60" name="Loop Attributes" width="90" x="313" y="75"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="xyz.*"/> <process expanded="true" height="540" width="907"> <operator activated="true" class="set_macro" compatibility="5.2.006" expanded="true" height="76" name="Set Macro (2)" width="90" x="112" y="30"> <parameter key="macro" value="plot_list"/> <parameter key="value" value="%{plot_list},%{loop_attribute}"/> </operator> <connect from_port="example set" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="generate_macro" compatibility="5.2.006" expanded="true" height="76" name="Generate Macro" width="90" x="447" y="75"> <list key="function_descriptions"> <parameter key="plot_list" value="replace("%{plot_list}","INIT,","")"/> </list> </operator> <operator activated="true" class="reporting:generate_report" compatibility="5.2.000" expanded="true" height="76" name="Generate Report" width="90" x="581" y="75"> <parameter key="report_name" value="report"/> <parameter key="format" value="HTML"/> <parameter key="html_output_directory" value="C:\Users\isak\Documents\testReport"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.2.000" expanded="true" height="60" name="Report" width="90" x="715" y="75"> <parameter key="report_name" value="report"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Data Table"/> <parameter key="renderer_name" value="Plot View"/> <list key="parameters"> <parameter key="plotter" value="Scatter Multiple"/> <parameter key="scatter_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_axis_y_axis_log_scale" value="false"/> <parameter key="scatter_jitter_amount" value="0"/> <parameter key="scatter_rotate_labels" value="false"/> <parameter key="scatter_multiple_axis_x_axis" value="T"/> <parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_multiple_plot_columns" value="%{plot_list}"/> <parameter key="scatter_multiple_jitter_amount" value="0"/> <parameter key="scatter_multiple_rotate_labels" value="false"/> <parameter key="scatter_matrix_jitter_amount" value="0"/> <parameter key="bubble_axis_x_axis_log_scale" value="false"/> <parameter key="bubble_axis_y_axis_log_scale" value="false"/> <parameter key="bubble_rotate_labels" value="false"/> <parameter key="parallel_rotate_labels" value="false"/> <parameter key="parallel_local_normalization" value="false"/> <parameter key="deviation_rotate_labels" value="false"/> <parameter key="deviation_local_normalization" value="false"/> <parameter key="series_rotate_labels" value="false"/> <parameter key="series_multiple_rotate_labels" value="false"/> <parameter key="som_jitter_amount" value="0"/> <parameter key="block_axis_x_axis_log_scale" value="false"/> <parameter key="block_axis_y_axis_log_scale" value="false"/> <parameter key="block_jitter_amount" value="0"/> <parameter key="block_rotate_labels" value="false"/> <parameter key="pie_absolute_values" value="false"/> <parameter key="pie_aggregation" value="none"/> <parameter key="pie_use_distinct" value="false"/> <parameter key="pie_explosion_amount" value="0"/> <parameter key="pie_3d_absolute_values" value="false"/> <parameter key="pie_3d_aggregation" value="none"/> <parameter key="pie_3d_use_distinct" value="false"/> <parameter key="ring_absolute_values" value="false"/> <parameter key="ring_aggregation" value="none"/> <parameter key="ring_use_distinct" value="false"/> <parameter key="ring_explosion_amount" value="0"/> <parameter key="bars_absolute_values" value="false"/> <parameter key="bars_rotate_labels" value="false"/> <parameter key="bars_aggregation" value="none"/> <parameter key="bars_use_distinct" value="false"/> <parameter key="bars_orientation" value="vertical"/> <parameter key="bars_stacked_absolute_values" value="false"/> <parameter key="bars_stacked_rotate_labels" value="false"/> <parameter key="bars_stacked_aggregation" value="none"/> <parameter key="bars_stacked_use_distinct" value="false"/> <parameter key="bars_stacked_orientation" value="vertical"/> <parameter key="pareto_rotate_labels" value="false"/> <parameter key="pareto_sorting_direction" value="Descending Keys"/> <parameter key="pareto_show_bar_labels" value="true"/> <parameter key="pareto_show_cumulative_labels" value="false"/> <parameter key="distribution_rotate_labels" value="false"/> <parameter key="histogram_absolute_values" value="false"/> <parameter key="histogram_rotate_labels" value="false"/> <parameter key="histogram_log_scale" value="false"/> <parameter key="histogram_number_of_bins" value="40"/> <parameter key="histogram_opaqueness" value="100"/> <parameter key="histogram_color_absolute_values" value="false"/> <parameter key="histogram_color_rotate_labels" value="false"/> <parameter key="histogram_color_log_scale" value="false"/> <parameter key="histogram_color_number_of_bins" value="40"/> <parameter key="histogram_color_opaqueness" value="100"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
