"Scripts errors after sql table has been deleted"
RLynx
After most recent upgrade I noticed this unpleasant behavior:
Correct and successfully working processes (which write data to a database)
are successful on the first attempt, but start throwing errors after I delete corresponding tables from database
and run these processes a second time.
Therefore, in order to run a process successfully again I have to reload a process file.
Thank you,
RLynx
Errors
SQL
Nils_Woehler
what scripts do you mean? Did you use the 'Write Script' Operator to write your own script that writes to the database?
Or did you set up a process with operators like 'Write Database'? If so please post your process like it is described here:
http://rapid-i.com/rapidforum/index.php/topic,4654.0.html
Best,
Nils
RLynx
I have corrected my question above - by "script" I meant "process".
I use Write Database operators.
Unfortunately, I can't post original process. I will try to recreate a simple example of the process with the same problem. Will keep you posted.
Thank you!!
RLynx
