I have a process with nested operators (Loop Example). I have to get an output from root operator. Loop example is a last operator and in XML defenition is
<connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/>
<connect from_op="Loop Examples" from_port="output 2" to_port="result 2"/>
in code I have
IOObject o1 = process.getRootOperator().getOutputPorts().getPortByName("result 1").getAnyDataOrNull(); // or getData()
IOObject o2 = process.getRootOperator().getOutputPorts().getPortByName("result 2").getAnyDataOrNull(); // or getData()
But it throws NullPointerException.
Complete process is defined below.
<process version="5.1.014">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="rm-report1-p2">
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true" height="645" width="1083">
<operator activated="true" class="read_csv" compatibility="5.1.014" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75">
<parameter key="csv_file" value="C:\Users\Zis\Documents\NetBeansProjects\seage\seage-launcher\report\report.csv"/>
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character_for_quotes" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="encoding" value="windows-1250"/>
<parameter key="0" value="ExperimentID.true.text.attribute"/>
<parameter key="1" value="ProblemID.true.text.attribute"/>
<parameter key="2" value="AlgorithmID.true.text.attribute"/>
<parameter key="3" value="InstanceID.true.text.attribute"/>
<parameter key="4" value="ConfigID.true.text.attribute"/>
<parameter key="5" value="SolutionValue.true.real.attribute"/>
<parameter key="6" value="Time.true.real.attribute"/>
<parameter key="7" value="p1.true.real.attribute"/>
<parameter key="8" value="p2.true.real.attribute"/>
<parameter key="9" value="p3.true.real.attribute"/>
<parameter key="10" value="p4.true.real.attribute"/>
<parameter key="11" value="p5.true.real.attribute"/>
<parameter key="12" value="p6.true.real.attribute"/>
<parameter key="13" value="p7.true.real.attribute"/>
<parameter key="14" value="p8.true.real.attribute"/>
<parameter key="15" value="p9.true.real.attribute"/>
<parameter key="16" value="p10.true.real.attribute"/>
<parameter key="17" value="att18.false.attribute_value.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<operator activated="true" class="generate_attributes" compatibility="5.1.014" expanded="true" height="76" name="Generate Attributes" width="90" x="112" y="210">
<parameter key="id" value="concat(ExperimentID,"-",ProblemID,"-",AlgorithmID,"-",InstanceID)"/>
</list>
<parameter key="use_standard_constants" value="true"/>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="set_role" compatibility="5.1.014" expanded="true" height="76" name="Set Role" width="90" x="179" y="75">
<parameter key="name" value="id"/>
<operator activated="true" class="replace_missing_values" compatibility="5.1.014" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="210">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="false"/>
<parameter key="attribute" value=""/>
<parameter key="attributes" value="|p9|p8|p7|p6|p5|p4|p3|p2|p10|p1"/>
<parameter key="default" value="value"/>
<list key="columns"/>
<parameter key="replenishment_value" value="-1"/>
<operator activated="true" class="multiply" compatibility="5.1.014" expanded="true" height="76" name="Multiply" width="90" x="447" y="75"/>
<operator activated="true" class="aggregate" compatibility="5.1.014" expanded="true" height="76" name="Aggregate" width="90" x="581" y="30">
<parameter key="use_default_aggregation" value="false"/>
<parameter key="attribute_filter_type" value="all"/>
<parameter key="default_aggregation_function" value="average"/>
<parameter key="SolutionValue" value="average"/>
<parameter key="p1" value="minimum"/>
<parameter key="p2" value="minimum"/>
<parameter key="p3" value="minimum"/>
<parameter key="p4" value="minimum"/>
<parameter key="p5" value="minimum"/>
<parameter key="p6" value="minimum"/>
<parameter key="p7" value="minimum"/>
<parameter key="p8" value="minimum"/>
<parameter key="p9" value="minimum"/>
<parameter key="p10" value="minimum"/>
</list>
<parameter key="group_by_attributes" value="id|AlgorithmID|ConfigID|ExperimentID|InstanceID|ProblemID"/>
<parameter key="count_all_combinations" value="false"/>
<parameter key="only_distinct" value="false"/>
<parameter key="ignore_missings" value="true"/>
<operator activated="true" class="store" compatibility="5.1.014" expanded="true" height="60" name="Store" width="90" x="849" y="30">
<parameter key="repository_entry" value="//SEAGE/rm-report1-p3"/>
<operator activated="true" class="aggregate" compatibility="5.1.014" expanded="true" height="76" name="Aggregate (2)" width="90" x="715" y="165">
<parameter key="id" value="count"/>
</list>
<parameter key="group_by_attributes" value="|id"/>
<operator activated="true" class="loop_examples" compatibility="5.1.014" expanded="true" height="112" name="Loop Examples" width="90" x="849" y="165">
<parameter key="iteration_macro" value="example"/>
<parameter key="parallelize_example_process" value="false"/>
<process expanded="true" height="674" width="1094">
<operator activated="true" class="retrieve" compatibility="5.1.014" expanded="true" height="60" name="Retrieve" width="90" x="45" y="210">
<operator activated="true" class="set_role" compatibility="5.1.014" expanded="true" height="76" name="Set Role (3)" width="90" x="246" y="210">
<operator activated="true" class="extract_macro" compatibility="5.1.014" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="75">
<parameter key="macro" value="val"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="attribute_name" value="id"/>
<parameter key="example_index" value="%{a}"/>
<operator activated="true" class="filter_examples" compatibility="5.1.014" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="75">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="id=%{val}"/>
<parameter key="invert_filter" value="false"/>
<operator activated="true" class="set_role" compatibility="5.1.014" expanded="true" height="76" name="Set Role (2)" width="90" x="313" y="75">
<operator activated="true" class="intersect" compatibility="5.1.014" expanded="true" height="76" name="Intersect" width="90" x="447" y="165"/>
<operator activated="true" class="sort" compatibility="5.1.014" expanded="true" height="76" name="Sort" width="90" x="581" y="165">
<parameter key="attribute_name" value="average(SolutionValue)"/>
<parameter key="sorting_direction" value="increasing"/>
<operator activated="true" class="multiply" compatibility="5.1.014" expanded="true" height="94" name="Multiply (2)" width="90" x="782" y="120"/>
<operator activated="true" class="aggregate" compatibility="5.1.014" expanded="true" height="76" name="Aggregate (3)" width="90" x="916" y="210">
<parameter key="minimum(p1)" value="average"/>
<parameter key="minimum(p1)" value="standard_deviation"/>
<parameter key="minimum(p2)" value="average"/>
<parameter key="minimum(p2)" value="standard_deviation"/>
<parameter key="minimum(p3)" value="average"/>
<parameter key="minimum(p3)" value="standard_deviation"/>
</list>
<parameter key="group_by_attributes" value="|InstanceID"/>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Retrieve" from_port="output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Intersect" to_port="example set input"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Intersect" to_port="second"/>
<connect from_op="Intersect" from_port="example set output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_port="output 1"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Aggregate (3)" to_port="example set input"/>
<connect from_op="Aggregate (3)" from_port="example set output" to_port="output 2"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Aggregate" from_port="original" to_op="Aggregate (2)" to_port="example set input"/>
<connect from_op="Aggregate (2)" from_port="example set output" to_op="Loop Examples" to_port="example set"/>
<portSpacing port="sink_result 1" spacing="72"/>
</process>
</process>
Thanks for ideas,
Jonh
