<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="638" width="748"> <operator activated="true" class="generate_data" compatibility="5.2.002" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.2.002" expanded="true" height="76" name="Naive Bayes" width="90" x="246" y="30"/> <operator activated="true" class="apply_model" compatibility="5.2.002" expanded="true" height="76" name="Apply Model" width="90" x="380" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.2.002" expanded="true" height="76" name="Rename by Replacing" width="90" x="514" y="30"> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="\(|\)"/> <parameter key="replace_by" value="_"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.002" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="30"> <list key="function_descriptions"> <parameter key="correct_prediction" value="label==prediction_label_"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
