<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.014"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process"> <process expanded="true" height="386" width="949"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.014" expanded="true" height="60" name="Generate Nominal Data" width="90" x="56" y="161"/> <operator activated="true" class="rename" compatibility="5.1.014" expanded="true" height="76" name="Rename" width="90" x="179" y="165"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="source"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="rename" compatibility="5.1.014" expanded="true" height="76" name="Rename (2)" width="90" x="320" y="161"> <parameter key="old_name" value="att2"/> <parameter key="new_name" value="target"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.014" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|target|source"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.014" expanded="true" height="76" name="Set Role" width="90" x="581" y="300"> <parameter key="name" value="source"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.014" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="165"> <list key="function_descriptions"> <parameter key="strength" value="rand()*5"/> </list> </operator> <operator activated="true" class="transition_graph" compatibility="5.1.014" expanded="true" height="76" name="Transition Graph" width="90" x="782" y="120"> <parameter key="source_attribute" value="source"/> <parameter key="target_attribute" value="target"/> <parameter key="strength_attribute" value="strength"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Transition Graph" to_port="example set"/> <connect from_op="Transition Graph" from_port="example set" to_port="result 1"/> <connect from_op="Transition Graph" from_port="transition graph" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
