I am trying to export reduced model from simlab to Kissoft setting bulk data to:
CMSMETH, 99999999, GUYAN
PARAM, KISSSOFT, YES
It does not create a .kss file, the only way I could create a stiffness matrix to be exported is using
PARAM, EXTOUT, DMIGPCH
In my setup I have an assembly to reduce and 6 nodes I use as ASET.
I tried to use Excite model reduction but it seems that it does not support export to kisssoft.
https://help.altair.com/hwsolvers/os/topics/solvers/os/cmsmeth_bulk_r.htm#cmsmeth_bulk_r
https://2021.help.altair.com/2021/hwsolvers/os/topics/solvers/os/third_party_software_intro_r.htm
Hello Federico Bosi,
Currently, SimLab support model reduction only for Excite, SimPack, Motionsolve, Adams.
If kissoft support any of the above formats, please use this.
Thanks & Regards,
Santhoshkumar
