awchisholm wrote:You could use the "set role" operator to change the type of the attributes you want to ignore to "ignore1", "ignore2" and so on. You can type the text you want directly into the parameter and you have to use different role types for each attribute.
I just could not find anything in the doc that says that only specific roles are used for clustering?
