OperatorChain - execute subprocess line by line
radone
radone New Altair Community Member
I have class OperatorChain which has two (extendable) inner ports:
- OutputPortExtender
- InputPortExtender
(see the figure below)
##-------Line 1------##
##-------Line 2------##
Is it possible to execute process in a "line by line" manner (i.e. port by port)?
Currently I call:
getSubprocess(0).execute();
I would like to save processing time and execute next "lines" only if the previous lines go well (something like AdaBoost).
The only possible way I know is to terminate the execution by throwing an exception in the inner operator. I am afraid that capturing exceptions can be much slower.
Thanks for any help.
radone
Welcome!
  • fischer
    fischer New Altair Community Member
    it seems like your "lines" are independent. Can't you make multiple subprocess and put a "line" into each?
    Best,
    Simon
  • radone
    The problem is, I expect the number of subprocesses would be approx. 40 (and might be even more).
    In case of subprocesses it should work, however the GUI interface will be quite .
    If the same would be possible in line by line approach it would be much better.
  • fischer
    just to make sure we are talking about the same thing: These 40 subprocess you are expecting, are all different, so the user has to do a lot of process design work anyway, right?
    Best,
    Simon
  • radone
    I expect these processes will be designed by genetic programming*, therefore it wont be much time.
    * I hope I will find some time to to contribute to RCOMM this year and present our work.
    radone
  • fischer
    that sounds cool! But if the process is designed by GP, it should not be a big problem that it clutters up the design perspective - after all the user will not really look at it, so you can go with 40 subprocesses. That sounds like the most reasonable idea to me.
    Best,
    Simon
Welcome!
Welcome!
