<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name="Process"> <process expanded="true" height="455" width="701"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="sum classification"/> <parameter key="number_of_attributes" value="6"/> </operator> <operator activated="true" class="generate_id" compatibility="5.0.8" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="principal_component_analysis" compatibility="5.0.8" expanded="true" height="94" name="PCA" width="90" x="313" y="30"> <parameter key="dimensionality_reduction" value="fixed number"/> <parameter key="number_of_components" value="2"/> </operator> <operator activated="true" class="join" compatibility="5.0.8" expanded="true" height="76" name="Join" width="90" x="447" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="PCA" to_port="example set input"/> <connect from_op="PCA" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="PCA" from_port="original" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
