<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="386" width="614"> <operator activated="true" class="loop_files" expanded="true" height="60" name="Loop Files" width="90" x="112" y="75"> <parameter key="directory" value="C:\Program Files (x86)\Weka-3-7\data"/> <process expanded="true" height="416" width="746"> <operator activated="true" class="read_arff" expanded="true" height="60" name="Read ARFF" width="90" x="45" y="75"> <parameter key="data_file" value="%{file_name}"/> </operator> <portSpacing port="source_in 1" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
Error transforming meta data transformation: java.lang.NullPointerException
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="416" width="746"> <operator activated="true" class="loop_files" expanded="true" height="60" name="Loop Files" width="90" x="112" y="75"> <parameter key="directory" value="C:\Program Files (x86)\Weka-3-7\data"/> <process expanded="true" height="416" width="746"> <operator activated="true" class="read_arff" expanded="true" height="60" name="Read ARFF" width="90" x="45" y="75"> <parameter key="data_file" value="%{file_name}"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="220" y="70"/> <connect from_op="Read ARFF" from_port="output" to_op="Decision Tree" to_port="training set"/> <portSpacing port="source_in 1" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="296" width="915"> <operator activated="true" class="loop_files" expanded="true" height="60" name="Loop Files" width="90" x="112" y="75"> <parameter key="directory" value="C:\Documents and Settings\Alien\My Documents\rm_workspace"/> <parameter key="filter" value="SVM.*8\.par"/> <process expanded="true" height="296" width="915"> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="45" y="75"> <parameter key="macro_name" value="file_path"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="180" y="30"> <list key="log"> <parameter key="file_name" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <operator activated="true" class="read_parameters" expanded="true" height="60" name="Read Parameters" width="90" x="313" y="165"> <parameter key="parameter_file" value="%{file_path}"/> </operator> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <portSpacing port="source_in 1" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
I think providing sample process will simplify our life
One of the more exciting announcements I can make here is a new marketplace for Rapid-X products and extensions which will be started soon. Here developers can offer their own extensions, operators, scripts, or processes and Rapid-I will provide all the technical and commercial infrastructure for the necessary transactions.
That mind reading software of yours works amazingly well over TCP, I need more details of the following yesterday....
