Original message from SourceForge forum at
http://sourceforge.net/forum/forum.php?thread_id=2040778&;forum_id=390413
Dear Community,
after loading "ExcelExampleSource.xml" or "CSVExampleSource.xml" and reading some EXCEL or CSV data without an error RapidMiner doesn't respond anymore and can only be closed by the kill command (Ubuntu 8.04). Can this be avoided?
Thanks
Richard
Answer by Ingo Mierswa:
Hello Richard,
I tried both operators here on my Linux system (Kubuntu) and other systems (SuSE) and did not notice any problems with these operators here. Are you sure you use a JRE 5 from SUN? Often on Linux some free variant like gcj is used which often does not work correctly with the graphical user interface.
Cheers,
Ingo
Answer by Richard:
Hello Ingo,
I just switched from Fedora to Ubuntu last week. As all the other Java applications worked fine from within the standard installation (openjdk), I didn't take this into account. After switching to Sun Java everything works fine.
Thanks
Richard
