Ask The Expert Series on November 21, 2023
Excel Worksheet Design "Excel Trapping" in Monarch Complete (DPS Mode)
The Session began with a brief overview of Excel Worksheet Design "Excel Trapping" in Monarch Complete (DPS Mode) before diving into the LIVE Questions.
 The Session began with our Expert reviewing the following:
The session began by Steve reviewing Excel Worksheet design in Monarch. Timestamp {0:00-12:55}
 - Steve began by showing opening Excel in Database Mode in Classic for customers that may only work within Classic.
- You can define fields, but take into a account that merging cells in Classic does not take the cells into one.
  - A limitation of the Database option is that it uses the name of the sheet and the fields properties are set/defined in place.
  - If you have multiple data sources then is easier to work in Data Prep Studio.
  - Bringing another file with different format creates problems with the automation process
- It throws a warning when it cannot find a solution for the issue.
  - In some cases, you may prefer to retain the old name while referencing the new field, so ensure that you perform the necessary mapping.
  - When selecting a new file, if the fields remain consistent but the sheet name differs, the project may generate a complaint.
Steve shows the process in Data Prep Studio and shows Excel Worksheet Design Mode and Data Base Mode. Timestamp {12:55-30:27}
 - Within Data Prep Studio you have the option to open the file with Worksheet Design Mode.
  - Steve demonstrates how to import efficiently all sources using Data Base Mode.
- Please note that it is essential to choose the "named ranges" to display all data sheets.
- Ensure that the option "Automatically sync columns with source data on load or refresh" is checked.
  - It is essential to update or map the field name on all sheets for consistency.
  - In Data Prep Studio is easier to append and replace cells to get to the same place as Monarch Classic.
  - Within Worksheet Design Mode it is not necessary to do the replace and the model structure is applied to all sheets.
Steve brought a more engaging and creatively structured design Excel report. Timestamp {30:27-39:44}
 - Fonts/formatting/coloring was brought in.
- Identify the target field and utilize the "Add Trap" feature.
  - Options such as "Number Field", "Font Attribute", "Font Size" and "Color" are available for customization.
  - Deselect irrelevant options, if any, and establish conditions.
  - Also there are options for Choices Alignment, Cell(design), Font and Value.
  - Then Steve created an Append using Trap on Exact Match.
LIVE and Pre-Registered Questions Submitted: Timestamp {39:44-50:08}
       - Once we have worked with the spreadsheets, can we export to prn file type in Data Prep?
- Unfortunately, Data Prep Studio does not have the ability to export to a prn file. It does have the ability to export to a delimited text file though.
  Additional Resources:
 Monarch Learning Guide   More Help for Excel Trapping
 Webinar- Spreadsheet Data Extraction- KB Article: KB0125130
