Important: This article is for authorizing from the command line. If you wish to authorize through ALMUtil GUI, please refer to Accessing the Altair License from the Altair License Utility.
1. Login to Altair One.
2. Go to the User Profile section of the Altair One Admin portal: https://admin.altairone.com/updateprofile.
3. Switch to the Authorized Machines tab:
4. In the top-right corner, click Generate Auth Code.
An authentication code will be generated.
5. Click the copy icon.
6. Locate the Altair License Utility.
- Altair 2021.2. You can also directly start it from <ALTAIR_INSTALL_PATH>\security\bin\win64\gui\almutil.exe (usually C:\Program Files\Altair\2021.2\security\bin\win64\gui\almutil.exe).
- On Linux, you can directly start it from <ALTAIR_INSTALL_PATH>/altair/security/bin/linux64/almutil (by default /root/2021.2/altair/security/bin/linux64/almutil).
7. Enter the following command in a terminal (Linux) or Command Prompt (Windows)
almutil -a1auth -code <code>
A message will indicate that the authorization succeeded.
You can now start using your Altair software.
Machine-wide authorization
By default the authorization will be only for the current user. To get a token that works for all users on the machine, use the following command. Please note that you will need administrator rights to run it.
almutil -a1auth -code <code> -system
Anyhost authorization
By default the authorization tokens are linked to the machine MAC addresses and will only work on that machine. If you need a token that can work on multiple machines or a machine with changing MAC addresses (e.g. on a VDI environment), you can get a anyhost token.
Important note: Anyone who has access to this token will be able to use your licenses. You can mitigate this risk by controlling the Allowed IP Addresses from the Altair One licenses administration website.
To get a anyhost token, use the following command:
almutil -a1auth -code <code> -anyhost
From there you can either authorize other machines through an authorization file or through an environment variable
Authorizing other machines through an authorization file
Copy the authorization file located at:
- %USERPROFILE%\AppData\Local\.altair_licensing\%COMPUTERNAME%\altair_hostedhwu.cfg (on Windows)
- $HOME/.altair_licensing/$HOSTNAME/altair_hostedhwu.cfg (on Linux)
For user level authorization, paste it on the machine you want to authorize under
For machine level authorization, paste it on the machine you want to authorize under
- %ALLUSERSPROFILE%\altair\altair_hostedhwu.cfg (on Windows)
- /usr/local/altair/altair_hostedhwu.cfg (on Linux)
Authorizing other machines through an environment variable
Define the following environment variable
ALM_HHWU_TOKEN=<authcode>
