I'm currently working for the first time in motionsolve, in my model I need to define a contact but I'm not sure of the collision I can expect from this.
In details, I've defined the model as shown in the following picture:
where the components 1,2 and 3 are free to rotate around a shaft in the middle (red dot). I've defined a contact between the two green part as shown in the following:
And applied a motion (as a velocity) in the joint in the middle:
In this way I obtain the expected motion from the system but there is complete penetration of the two green bodies (where I defined the contact).
I think the contact is correctly detected because I have the contact pressure and other informations in the results, but there is no impact.
I have the expected impact (and stop of the body) if I define a gravity accelleration on Z. So I think that the problem is for the motion that doesn't stop when impact happens? (I tried also with a force and get the same results)
