Configure License Path
The license can be configured in Simlab using the following ways:
SimLab Installation
Using configure.exe
Manually edit the vpinit.bat file
SimLab File > Licensing
The license can be defined on the installer page as either server or standalone (node-locked) licenses.
The license defined in the installer page will be written along with the ALTAIR_LICENSE_PATH environment variable in the vpinit.bat file available in SimLab installation location.
Configure.exe
The License can be defined or changed through the configure.exe available under the Simlab installation location.
Open configure.exe and define either server or standalone (node-locked) license in Choose License page. This will update the pointed license under ALTAIR_LICENSE_PATH env in the vpinit.bat file.
After SimLab installation, ALTAIR_LICENSE_PATH env can be defined or changed by simply editing the vpinit.bat file available in SimLab installation location.
Open the vpinit.bat file in notepad, point the required license under the ALTAIR_LICENSE_PATH env and save it.
This License Setup dialog can be used to define the server and standalone license.
The hosted license can also be defined using the License setup.
Check which license is used by Simlab
The user can check the License used by Simlab using the following ways:
File > Licensing
System info
License setup can be used to check which license is used by Simlab.
System Info
The user can also check the license being used by SimLab from File > Help > System info, the license information is written in the System info.txt file.
