Create a cushion effect using PolyNURBS
ArjunA_22390
ArjunA_22390
edited April 2022 in Altair HyperWorks
This article shows how to use PolyNURBS tools to create soft good or cushion effect
  1. Select the vertices you want to chamfer
  2. Right click - Chamfer
  3. Hover over one of the vertices until you see the diamond graphic. (selection stays persistent)
  4. Click and drag to chamfer selected vertices
  5. Switch to faces, using D
  6. Extrude the faces down using the mouse or by an exact amount
Welcome!
Welcome!
