Hi All!
I want to create and simulate two cases at the same time - one case has springs attached to the part + forces, while the other one has only forces and inertia relief. I model the springs as 0D springs with a PBUSH property. However, I don't select the springs in the load collectors (they seem to be applied nevertheless) and thus cannot create one load step with springs attached and one load step with forces only + inertia relief. Is it possible to do to create the two load steps? I want to use the two different load steps for a topology optimization.
