This study demonstrates Altair Radioss capabilities to simulate ballistic impact on tanks filled with liquid.
The model units are g, mm, ms, Mpa. The model has 1254986 elements, 1344051 nodes. This model should be ran using multiple cores (performance details can be found in the attached presentation). The radioss version 2022.1 should be used in order to reproduce the results.
The physical phenomenon explanations, the methodology and the results can be found in the attached report.
Refer to Altair solution for ballistic impact on water tank.ppsx attached to this project.
