Overview
A set of bulk data for Optistruct, to produce the same flexible body (CMS method) with different contents (different size).
The attached zip, contains an example of Rod, defined with a 3D mesh elements (tetra) and different options to visualize at different level of details the results.
 Each model is usable for multibody purposes (MotionView & MotionSolve) and produce same results (if not used for flexible contacts).
 The models are related to KB0124385 How To article.
