Overview
This script is set up to look for a tpl file in the directory where the tcl is located. Then it goes through each iteration folder present in the same directory as the script. It grabs the punch file in each folder, loads the report template and applies the same in "append" mode for every punch file per folder. ***** It helps to quickly load files/parameters to report templates when you have results from several iterations
The script is to be placed in a directory containing >>>>multiple iteration folders - each folder containing a result file (in this case a punch file) >>>>a tpl that calls this pch file
Functionality
XY Plots
Subfunctionality
Options
