Overview
Assembly Hierarchy Structure can be created in HC11 and same can be seen in HyperView11. Around 40 Ls-Dyna users are using this script for seeing assembly structure. It would be greate, if you could consider to implement this in core of HV12.0
Just copy the script in altair instal directory and call it using File/Run script.
Limitation
Can read and generate assembly hierarchy from Master key file. Cannot read the xmls from Include file. Will update.
Functionality
Browser
