Overview
Attached is the source code for the Standard Rolling Friction model using version 3.6 of the API. Please note this is Rolling Friction only, please add a Base model from the EDEM GUI or API.
The source code consists of the CPU-API code updated to version 3.6 and the GPU-API code supplied as the file standardRollingFriction.cu.
To use the CPU-API code should be compiled into a library file (.dll file also provided in the zip to be used directly without compilation). When running a simulation if the .cu file is in the same location as the library the model will be GPU compatible, otherwise it will run on CPU only.
