Gravity Loads in X, Y, Z
jkrist2696
jkrist2696
edited May 2024 in Altair Exchange
Overview
This collection of scripts includes the following demos for Inspire:
1. Preprocessing script which creates fasteners, constraints, and gravity loads in X, Y, and Z directions
2. Postprocessing script which takes snapshots of each loadcase results
3. Example of how to use the scripts via command-line
4. Example of how to use the script via a custom Inspire Extension
Pre-Requisite
Install Inspire v2023.1 (only version tested with)
1. Unzip the folder to a working directory
2. Open script(s) and run within Inspire
(OR) Run from command-line with your working directory
(OR) Add extension, import the .step file, and run extension
Welcome!
Welcome!
