Create Derived Load Cases From Excel *csv
Chayan
Chayan
edited April 2022 in Altair Exchange
Overview
This script helps to create derived load cases (linear superpostion) based on an Excel template (attached). It is easier to define many superpostions in Excel than in HV, this script just converts the *csv into a *cfg that could be imported into HyperView.
1. Create Excel load case matrix (see attached template).
2. Export it as *csv .
3. Run script (*csv has to be selected). The *cfg will be created.
5. Import *cfg in DerivedSubcaseGUI.
Limitation
Be sure to set the subcase IDs in Excel correctly
Functionality
Results
Subfunctionality
Derived LoadStep Linear Superposition
Welcome!
Welcome!
