Compose script to clean overlapping curve-X-vector
User: "Sebastian_Karp"
Updated by Sebastian_Karp
Overview
This Compose script will scan a plotting result file, and for all outputs found it will create a new output and write all to an .ABF-file.
The outputs are cleaned up when necessary w.r.t. their X-vectors, in case there was an overlap. The new .ABF-file will contain all original outputs in a cleaned version. So the new outputs' X-vectors are continuously increasing.
Pre-Requisite
Open the .OML-script in Compose and edit line 4 to reference your current plotting result file, that will be scanned.
If the original curve has such overlaps in X
then this output will be cleaned to have the X-vector continuously increasing.
Edit the referenced original file to be scanned as described above, and RUN the OML-script. A new .ABF-file will be created in the same folder as the original file.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
