Overview
Automates force plot from dyna (can be adjusted to any solver HG reads) time history to plot axial vs shear resultant forces with inputs of beam ids from user in a text file. before plotting hg auto loads a limits curve before loading the force plot.
Run the tcl. The path to the mvw file is hard coded. So you need to adapt it as per your machine before running it Attached report template (ELOUTreport.tpl) takes absolute axial force.
Functionality
XY Plots
Subfunctionality
Macros
Interface
LS-Dyna
