Overview
This Script will check if component ID is
>= lower boundary value
and
<= upper boundary value.
Boundary values are handed over as arguments by the execution pattern (see below).
If condition is matched, component will be re-colored itself (if no set-name is handed over as argument), or a set is created with these components. Show / Hide of the set can be used to show a colored display of these components (components not re-colored itself).
If set name already exists, components matching the pattern will be added to this set.
Pre-Requisite
Run script from DropDown File > Load > Script
Enter execution pattern through TCL Console (activate Console by DropDown "View").
Execution pattern examples:
- ColorPartsByID 2500 2999 blue "SetName7"
>> Matches 2500-2999 for creating Set - ColorPartsByID 2500 2999 blue
>> Matches 2500-2999 for directly recoloring components
Post-Requisite
