🎉Community Raffle - Win $25
Join and Win
Read Results From Doe Run Directory and Write Target Curve as CSV in Corresponding Runfolder
User: "Chayan"
Updated by Chayan
Overview
Reads result file from individual run folders and writes xy data in to CSV file for a given run directory.
For Batch Mode from command line "C:\Program Files\Altair\110.\hw\bin\win64\hw.exe" -b -tcl "\batchimportexportcurves.tcl" "\to1report.tpl" "\fevRBT01"
1) point to parent directory
2) point to T01 or other result file
3) point to the tpl file created using the file in 2)
Limitation
In step 2 , it is assumed that the file specified here is the same as all the DOE runs. A small change can be made to just identify a specific file type and make it work for cases where file names are not the same.
Functionality
XY Plots
Subfunctionality
Statistics
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
