Overview
This script help compare responses from 8 iterations at one time. User can load all the files at once though macro GUI. Each file is assigned a color so all the curves from this file will be plotted with only one color making it easy to compare multiple curves. User can select files to compare and plot. The subcase and responses are provided with up/down arrow to browse through all the curves. Today this is not possible in HG directly. User will have to load the file everytime and select a response and subcase to plot for every file and every curve. This is time cosuming. Also it would not be possible to distringuish between the curves as to where they are coming from. This utility provides all the detailed names of the files, notes and also a particular file specific color to easily identify curves.
Copy all the files at one location Source NVH_ComparePlots_GUI10.3.tbc file Load files to plot Select file number buttons to plot simultaneously. If different response from same file needs to be plotted then use the arrow button to expand the GUI and select the same file with different response and click on plot.
Limitation
No known limitations.
Functionality
XY Plots
Subfunctionality
Macros
