Overview
Attached is the source code for the Relative Wear model using version 3.6 of the API. Please note this is Relative Wear only, please include a Base and Rolling Friction model into any simulation.
The source code consists of the CPU-API code updated to version 3.6 and the GPU-API code supplied as the file relativeWear.cu.
To use the CPU-API code should be compiled into a library file (dll file also provided in the zip to use directly). When running a simulation if the .cu file is in the same location as the library the model will be GPU compatible, otherwise it will run on CPU only.
