Overview
Attached is the source code for the Hertz-Mindlin model using version 3.7 of the API. Please note this is Hertz-Mindlin only, for rolling friction please add a rolling friction model from the EDEM GUI.
 The source code consists of the CPU-API code updated to version 3.7 and the GPU-API code supplied as the file hertzMindlin.cu
Pre-Requisite
For information about compiling EDEM API Models please see:
 https://community.altair.com/csm?id=kb_article_view&sysparm_article=KB0037690
 or the EDEM Help:
 https://help.altair.com/edem/programming_guide.htm
 More EDEM and EDEM API Tutorials can be found here:
 https://community.altair.com/community?id=community_blog&sys_id=5e7dc459979de950e3b0361e6253afae
To use the CPU-API code should be compiled into a library file. When running a simulation if the .cu file is in the same location as the library the model will be GPU compatible, otherwise it will run on CPU only.
