Different Pulse demos that illustrate multiple use cases.
Demo
Required Products
GTA_v2022.2
End-to-end modal analysis process. Including selection of geometry and automated PowerPoint report creation.
Inspire, HyperMesh, Optistruct, HyperView and PowerPoint
HighFrequency
ThermoMechanics
v2022.2
High frequency analysis solution on Feko, postprocessing results through Compose and execution of thermal analysis solution on Optistruct.
CADFeko, Compose, HyperMesh, Optistruct and HyperView
Multifidelity
LinearStatic
Modification of geometry in Inspire using extension manager and execution of a 2D or 3D analysis based on user input. If task exemplified.
Inspire, HyperMesh, Optistruct and HyperMesh Post
Rigidity_v2022.2
Inspire, HyperMesh, Optistruct, HyperView and SimLab
Parametric
CATIA_v2022.2
Modification of CATIA geometry through parametrized Excel file followed by a linear static analysis
CATIA V5 6R2018, Excel, Compose, Optistruct and Inspire
Add the attached folder to your Pulse Library to access the demos.
Share your models, scripts, workspaces, and more with the Altair Community.
