Is there a way to create a flexible body in Optistruct to use in RADIOSS?
Silvio G.
Silvio G. Altair Community Member
edited January 2024 in Community Q&A
Good morning,
I'm trying to create a flexible body input file with Optistruct to be used in a subsequent RADIOSS run, but I couldn't find any valuable information in the Help Manual. It looks like Optistruct can output the flexible body only for these softwares: for Fatigue Analysis (FEMFAT, Design Life, FE-Fatigue, and FE-SAFE), Multibody Dynamic Analysis (AVL EXCITESIMPACKROMAXADAMSRecurDynRicardoVirtual LabGT-SUITE, and MASTA), and Fluid Structure Interaction Analysis (AcuSolve). Additionally, superelement output for KissSoft and OP2 file output for STRENGTH2000 are available.
Is there a way to tell Optistruct to write the flexible body file in the RADIOSS format .fxb or at least in a format that the RADIOSS card /FXBODY could manage?
Thank you for your help,
Silvio
Welcome!
Welcome!
