Following my (deleted) post on RADIOSS, I performed an implicit solution of the problem using optistruct and it went surprisingly well. Right now I am not in a position to tell if the results agree with those obtained from a different solver (NASTRAN) however they look rational. What I would like to know is if it is possible to have results related to composite damage using optistruct. The problem was a simple progressive failure analysis and within the MAT8 card I entered the values for Xt, Xc, Yt, Yc, S (P12C, P12T I couldn't locate). However in hyperview I couldn't see any option related to 'damage' although in the relevant card (global_output_request) 'damage' option was selected.
Should you need any additional information, I can provide you the .fem input file.
PS: I made a run of the simulation by including 'Energy' and 'Failure' options in the output request. In hyperview there were options for failure, but no results. My failure options are related to Puck failure criterion and not Tsai-Wu. Is that why I didn't see anything in HyperView? Is there a way to include this criterion (Puck) within the MAT8 card?
