the picture showes the first two eigenmodes of a steel ruler, analysed with normal mode.
The model is attached (rename the second file to xxx.hm).
In a hardware test the low frequencies will be influenced by the gravity.
Example: different frequencies in horizontal an vertical position of model.
How can I calculate Eigenfrequencies/ Eigenmodes WITH Gravity?
(Eigenmodes of a prestressed structure)
ThankX, Dirk
