Large Rotations in Analysis
in postprocessing, you might find a behaviour, where your model seems to be rotating very heavily and is deformed in the results view.The reason might be that you need to apply Non-linear geometry analysis, when having high deformations or rotations. The linear geometry assumption is only valid for small deflections, where the error is negligible. For an example as shown above, please use NLGEOM as a subcase type. See the description in the online help and below.
Jan
