Hello experts,
Is there any way using UDF that I can modify the permeability of the porous media? I am able to use the porosity model but I want to change the permeability itself as other properties (like density, viscosity, etc) using UDF.
https://help.altair.com/hwcfdsolvers/acusolve/topics/acusolve/porosity_model_acusolve_com_ref.htm
Thanks.
It looks like the various permeability parameters can have a multiplier function attached. If you make that multiplier function be type = user_function, maybe that will give you the access you desire.
