I'm getting this error when trying to run a CFD simulation
ERROR: input not prepared; try: acuRun -do all
Any help would be greatly appreciated!
Thanks
How are you attempting to run AcuSolve?
Are you running from HyperWorks CFD? If so - can you add a screenshot of the job launch panel - wide enough to show all input fields - directories, path to the solver, etc?
Are you launching from the Command Prompt? If so - what is the exact command you typed?
I'm running it from HW CFD, here is the screenshot:
It's very likely related to the spaces and/or the + in the directory (in any of the directories - complete path) and problem name. As a general rule I always recommend not using spaces - use underscore instead - and not to use characters like + in directories or problem names.
Yes, thank you it seems to be working now!
