I am working on a hydraulic circuit and came accross Directional control valve. According to the actually design i need 6/3 DC valve, which different configuration from the one which is available in Altair.
I need help in configuring that available block to the one i need. i will be tagging both the available block and the block i need. How to build the lookup table for the same!?
