I am trying to model a bullet impacting on a composite panel. The projectile is made of two different materials and is meshed with SPH particles (all the same size and network). The panel on which the projectile impacts is made of an upper layer (meshed with solid tetra elements) and a lower one made of thin-walled cells (meshed shell). The simulation ends abruptly due to an excessive Total_Energy error (-50%, I set this). In the time of just one cycle, the energy collapses and the total mass of the SPH particles goes to zero. This is what you see in the 0001.out file:
CYCLE TIME TIME-STEP ELEMENT ERROR I-ENERGY K-ENERGY T K-ENERGY R EXT-WORK MAS.ERR TOTAL MASS MASS ADDED
4100 0.3782E-04 0.9411E-08 SOLID 307062 -17.8% 0.2079E+06 0.1968E+06 63.08 0.000 0.9465E-04 0.9983E-04 0.9448E-08
4125 0.3805E-04 0.9412E-08 SOLID 307062 -17.9% 0.2093E+06 0.1950E+06 61.86 0.000 0.9465E-04 0.9983E-04 0.9448E-08
MESSAGE ID : 206
** RUN STOPPED: ENERGY ERROR LIMIT REACHED
4126 0.3806E-04 0.8186E-08 NODE 395436 -50.0% 0.5115E+05 0.1949E+06 62.02 0.000 0.9465E-04 0.9983E-04 0.9448E-08
For contacts between SPH particles and solid or shell elements I used TYPE 7 interface. What could be the error?
HM file attached.
