I have a model outputting both a T01 file and an H3d file. I would like to have nodal forces/moments for a particular node (TH/NODE output) and forces/moments for a particular RBODY (TH/RBODY) output. I am able to get the outputs in the H3d file if I load that into hypergraph, but if I try to load the time file I am not able to get any output requests and I get an error message, "Unable to recognize: /path/fileT01". I have tried to translate the file using HGTRANS but that application also is not able to open the T01 (reference here: https://community.altair.com/community/en?id=community_question&sys_id=0d66ccf61b2bd0908017dc61ec4bcb2c)
The H3d file is disadvantageous due to to its size, so I would prefer not to use this output.
Please see below for the engine file requests:
/RUN/Filename/1/
0.010000000000000
/MON/ON
/PRINT/-500/55
/VERS/2023
/H3D/DT
0.000000000000000 1.00000000000000E-04
/H3D/NODA/DMASS
/H3D/NODA/FREAC
/H3D/NODA/FRES
/H3D/NODA/FVEL
/H3D/NODA/MREAC
/H3D/NODA/VEL
/H3D/NODA/VEL/TMAX
and the TH requests:
/TH/RBODY/2
#thgroup_name
RBODY
# var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
F M FI MI R
# Obj_ID1 Obj_ID2 Obj_ID3 Obj_ID4 Obj_ID5 Obj_ID6 Obj_ID7 Obj_ID8 Obj_ID9 Obj_ID10
1153
/TH/NODE/1
#thgroup_name
RBODY_TH
DEF
# node_ID skew_ID node_name
1517702 0
Thanks
