Hello All,
I wanted to perform FRF with test input which are in Freq (Hz) vs magnitude (G2/Hz). I added test input as curve and assigned it through RLOAD1 Tc option. Rest of parameters are same as FRF. Now analysis is done but stresses are very high like 2000 MPa which are doubtful as mounting part is sufficiently thick.
I want to check if my process is correct. If not, then what is correct process.
With my current approach stress are very high so which are the areas i have to check to get stresses in plausible range.
Note: While adding magnitude (G2/Hz) i have multiplied these values with 9810
Request your support. Thank you.
