Tip: Unable to continue executing code as mpich2mpi.dll cannot be found.
Can you attach the complete .Log file - and include specifics about your machine (OS, Version, etc).
Are you able to run AcuSolve-only simulations?
Can you attach the complete .Log file - and include specifics about your machine (OS, Version, etc). Are you able to run AcuSolve-only simulations?
AcuSolve-only simulations cannot be run either! Really weird
win 10
Please attach the complete input (.inp) and Log (.Log) files.
Thank you very much for your reply, I have added two attachments.
Have you run the solver successfully before - or is this the first attempt?
Can you attach a snapshot showing the problem files (.inp, MESH.DIR, etc) and the full path of that directory - to show the complete names of all the directories up to and including that directory?
Have you run the solver successfully before - or is this the first attempt? Can you attach a snapshot showing the problem files (.inp, MESH.DIR, etc) and the full path of that directory - to show the complete names of all the directories up to and including that directory?
Sorry, I have lost these files.
I can run the model normally using hyperworks CFD 2022.3. But, then it cannot be coupled with EDEM2023?
Sorry, I have lost these files. I can run the model normally using hyperworks CFD 2022.3. But, then it cannot be coupled with EDEM2023?
Possibly - but not guaranteed. The coupling process does sometimes change.
Which licensing are you using - Student Edition?
