Hi there,
Im looking for some help to understand the differences between the results from the size optimization, in the displacement and failure index, between the result from the analysis and the result from the optimization itself (the ones that you see in Hyperview when you choose to observe the last iteration). Does it make sense to have reasonable values in the last iteration results for the load case, and when i import the' _shufflingX.fem' and run the analysis again, the results are different and do not agree with my boundary conditions?
Thanks
Diogo
