I am new to Optistruct and I have a problem applying the correct method for SPC. I have a disk on the xz plane with a certain thickness and internal diameter. 3D meshing was done. I created RBE2 on the internal region with a master node at the center of it. To fix the disk, I created SPC with a free rotation around the y-axis (DOF 5) so that the disk can rotate. A tangential force is applied on the external of the disk. The result is very weird as the disk expands.
Please assist me with this.
