Hi,I would like to get forces and moments on a defined section of 3D Bolt as an output in text format in Optistruct non-linear case. Can you please guide me in such case?Thanks.
You have to create a section in HM and OptiStruct will write the forces in the .out file.Use this link to learn how to do it: https://help.altair.com/hwsolvers/os/topics/solvers/os/section_bulk_r.htm?zoom_highlight=sectionYou can also use FBD tool in HV for using free body diagrams:Request GPFORCE(H3D,FBD) = ALL - When asking for GPFORCE you can see these forces by using FBD in the HV session (select advanced options).Use this link as a reference: https://altair.service-now.com/csm?id=kb_article&sys_id=91f340bcdb418510cfd5f6a4e2961943I hope this helps you.Thank you very much,
