I'm currently working on characterizing a honeycomb material, and I've conducted a compression test to obtain a stress-strain curve. Now, I'm considering the appropriate method for characterizing this material in Radioss. Below is the curve:
Given that it's a honeycomb material, my initial inclination is to characterize it using /MAT/LAW28 (HONEYCOMB). Accordingly, I believe I should extract the Young's Modulus (E) from the initial portion of the curve, and the yellow region should be incorporated into the YFUNCxx section, starting from 0 strain. Am I correct in this understanding? Given that it is compression, strain must be negative.
I've also been contemplating characterizing it as /MAT/LAW36 (PLAS_TAB). Would the rationale for the graph be similar?
So, what I'm trying to grasp is how the program handles the data. My assumption is that it simplifies the initial slope by providing the Young's Modulus, and then proceeds to the "yellow part of the picture," continuing from there. Am I correct in this understanding?
Thanks in advance
