I would like to do an optimization with a constraint on fatigue life of a component.
The problem is that I don't have a concentrated load with his load history but I have a dynamic pressure which I imported with two csv file. In both of this files I have the coordinates of the points where the pressures are applied, in the first I have the real part of this dynamic pressure and in the second I have the immaginary part.
Then I created a loadstep with card freq.resp.(direct) in which I selected as DLOAD the loadcollector I created to include the real part and the immaginary part of the dynamic pressure and in FREQ I selected the load collector that I created to determinate the range of frequency I want to study.
Now I would like to do an optimization trying to maximize the percentage of volume to remove but I would like to have a constraint on fatigue life.
So I created a response with card fatigue and I've gone in dconstraint. I selected lower bound and wrote 20000 and selected as response the response fatigue that I created before.
The problem is that when I select the loadstep and then create the dconstraint the software gives me an error saying that the loadstep is not compatible with the type of resonse.
How can I resolve this problem?
